Transmission swap?
80,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
MARCHER80
Will a manual transmission from a 99 dodge Dakota replace an automatic transmission in a 99 dodge Durango?
Apr 15, 2023 at 5:51 AM
  • 110,251 POSTS
If they have the same engine size and both are 2wd, it should work. However, you need to install a clutch pedal as well as the shifter. Additionally, the driveshaft may need modifications when it comes to length.
The Durango has a 5.9L. I wouldn't recommend using the transmission from a 4-cylinder or the 3.9L engine.
Let me know if I can help.
Apr 15, 2023 at 3:23 PM
MARCHER80
Got it in but won't crank up.
Apr 16, 2023 at 9:26 AM
  • 110,251 POSTS
Are you referring to the starter not engaging, or the engine won't start? If it is the starter, how did you bypass the neutral safety switch?
Apr 16, 2023 at 11:35 AM
