I would like to know if a transmission from a 1993-1995 Buick Roadmaster will work on a 1992 Buick Roadmaster?
Nov 18, 2018 at 1:00 AM
✓Experienced Mechanic
It should but to be sure check the electrical connector pin count to make sure they are the same if you need to you can upload and image of both connectors and I will check for you. Cheers Ken
