Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Silverado
Drivetrain
Transmission
Interchange
Transmission swap
1999 CHEVROLET SILVERADO
258,673 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CHEVYLOVER1999
MEMBER
Will a 1998 4l60e transmission fit in my 1999 Silverado? Need to know before a buy.
Feb 18, 2019 at 1:43 PM
Experienced Mechanic
Good morning,
They both need to be four wheel drive. Make sure of that first.
Look at the electrical connector on the transmission form the body and make sure it is exactly the same.
If they are the same then good. You will be good to go.
Feb 18, 2019 at 7:41 PM
CHEVYLOVER1999
MEMBER
They are both 4x4 will their be any difference in the trans wiring harness?
Feb 20, 2019 at 3:51 PM
You will need to compare the harness plug at the transmission from your old one to the replacement. They must be the same.
Feb 20, 2019 at 8:34 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
