Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Drivetrain
Transmission
Interchange
Transmission swap
2007 TOYOTA CAMRY
250,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NIKKO1220
MEMBER
What do i need to put a 2003 Camry four speed u241e transmission for replacing my 2007 five speed u250e transmission?
Jun 5, 2019 at 4:35 AM
Experienced Mechanic
Good evening,
You will need a complete wiring harness, Computer and axles for this conversion.
I do not recommend you do this conversion. I would just get the correct transmission for the car.
Jun 5, 2019 at 8:28 AM
NIKKO1220
MEMBER
They use same axle.
Jun 5, 2019 at 12:37 PM
Okay, but the rest is not the same and cannot be adapted without the other items listed.
Jun 5, 2019 at 7:19 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
