Will a transmission from a 2003 Dodge ram 1500 fit my truck listed above it is a 1500?
Nov 7, 2016 at 10:32 AM
KOOLCADDY6
✓Experienced Mechanic
I think a 2003 Ram transmission is a 45RFE full electric and 1999 is a 46RH and it uses bands and electronic gov. you need to see if the engine in the 2003 is a 5.2 or a 5.9. if not it wont. the transmission wont even bolt up to the 4.7 or the 5.7 that are normally used in the 2003 1500's.
