I have a 2007 Ford Crown Victoria police interceptor transmission, it's going into a 2004 F150. Will I need a shorter driveshaft?
May 8, 2020 at 4:39 AM
✓Experienced Mechanic
Okay, the Crown Victoria has to be the same 4R70W. If it is not, it will bolt in but will not be controlled electronically.
Can you give me the number off it. the letter you listed are for assembly plant location and date.
Mar 24, 2021 at 6:37 AM
CHEFCOREYWRIGHT
MEMBER
PKE DP0
7P134776
I attached a image of the label on the drivers door.
Can you give me the 2 letter code for the transmission?
Image (Click to enlarge)
CHEFCOREYWRIGHT
MEMBER
The transmission going in is RFF3UP7A040AA.
CHEFCOREYWRIGHT
MEMBER
Found it there?
CHEFCOREYWRIGHT
MEMBER
Hey Roy, is there a reason the transmission seems twisted and bolts have to be forced into the motor?
Can you post a picture of what you see?
CHEFCOREYWRIGHT
MEMBER
Okay, so basically we got the torque converter bolts on and then the transmission bolts were not lining up on the one side. it seems like the transmission twisted there because there's too much pressure on the bolts.
