Transmission stuck in first gear
1996 FORD EXPLORER
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
TEDDYBEAR7269
My transmission is stuck in low gear and not wanting to shift into park. what is wrong?
Apr 6, 2018 at 10:05 PM
Good evening.
Do you mean the shifter will not move up to park or down to a lower gear?
Apr 7, 2018 at 11:17 AM
TEDDYBEAR7269
I cannot get it to go from first to park. I cannot understand it the shifting on inside works, but transmission is in low and will not go to park so I can start it.
Apr 7, 2018 at 9:35 PM
Okay, there is a shift cable that runs from the shifter to the transmission. this cable can fail from debris inside the cable that prevents it from moving fully in your selection of gears. this needs to be confirmed by someone who is familiar with the workings of the cable.
if it i determined it i the cable it needs to be replaced. the cable is about eighty to ninety bucks and the labor is about fifty bucks.
Apr 7, 2018 at 9:44 PM
TEDDYBEAR7269
Okay. I will check it out and see if that works. thanks Roy.
Apr 7, 2018 at 9:47 PM
You are welcome. keep us updated.
Apr 7, 2018 at 10:26 PM
