Transmission stuck in fifth gear
1995 CHEVROLET S-10
234,361 MILES • 4.3L • 6 CYL • 2WD • MANUAL
RONLEE6659
Had just put new clutch pressures plate throughout bearing and slave cylinder started driving down the road one day and the truck stayed stuck in fifth gear. shifter seams as if it is out of gear but it is stuck in gear.
Jun 4, 2019 at 2:03 PM
  • 110,244 POSTS
Welcome to 2CarPros.
It sounds like the shifter linkage has come apart or disconnected at either the transmission or in the vehicle. I just searched for twenty minutes and can't find a picture of the linkage. However, put the parking brake on and block the wheels. Then you will need to crawl under the vehicle and inspect the linkage that attached to the transmission to see if something has come disconnected or has broken. You should have a helper in the vehicle with his foot on the brake while under the vehicle and also, have them shift through the gears to confirm movement in the linkage. if you see something disconnected and are not sure if it is the problem, up load a picture for me to see.
Let me know if I can help.
Jun 4, 2019 at 2:59 PM
