Transmission speed sensor
147,000 MILES • 3.4L • V6 • TURBO • 2WD • AUTOMATIC
MSMARTINI4
I would like to know how to replace the transmission speed sensor of my truck?
Jun 2, 2016 at 7:11 AM
HMAC300
  • 48,601 POSTS
pretty much disconnect the electrical connection undo a bolt and pull old sensor out make sure you lube o-ring on new one and reverse for install. it is at back the of the transmission, so if you lose any fluid it would be minimal.
Jun 2, 2016 at 9:06 AM
