Transmission Speed Sensor?
2006 NISSAN PATHFINDER
156,000 MILES • 2WD • AUTOMATIC
DCHAU
Need help locating. Ill attach image of the transmission, please circle/highlight where the INPUT TRANSMISSION SPEED SENSOR should be at.
Aug 15, 2025 at 5:48 PM
  • 55,433 POSTS
There are two of them inside the transmission, you will need to remove the pan to get to them. Turbine Revolution Sensor 1 and Turbine Revolution Sensor 2. Here are both sensor locations. Check out the images (below). Let us know if you need anything else.
Aug 16, 2025 at 12:55 PM
DCHAU
I was told it could be replaced from the outside of the transmission, that's not true?
Aug 16, 2025 at 2:10 PM
  • 55,433 POSTS
Yes, that is not true, sorry.
Aug 17, 2025 at 4:57 AM
