Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lesabre
Drivetrain
Transmission
Transmission sound
1993 BUICK LESABRE
235,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DROB365
MEMBER
When at a steady speed in overdrive the car makes a low pitched sound. if given gas the sound goes away.
Mar 23, 2019 at 4:10 AM
Experienced Mechanic
Good afternoon,
This sounds like it could be a torque converter making the noise.
How long since you changed the fluid and filter in the transmission?
I would start there.
Mar 23, 2019 at 8:20 AM
DROB365
MEMBER
Fluid and filter were changed at 200xxx. is it possible to just be the noise the car makes? I haven't owned it long so I'm not sure what a normal sound would be from it.
Mar 23, 2019 at 11:32 AM
No. The noise is not normal.
I would still have the fluid changed.
Mar 23, 2019 at 11:36 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
