Transmission sound
235,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DROB365
When at a steady speed in overdrive the car makes a low pitched sound. if given gas the sound goes away.
Mar 23, 2019 at 4:10 AM
Good afternoon,
This sounds like it could be a torque converter making the noise.
How long since you changed the fluid and filter in the transmission?
I would start there.
Mar 23, 2019 at 8:20 AM
DROB365
Fluid and filter were changed at 200xxx. is it possible to just be the noise the car makes? I haven't owned it long so I'm not sure what a normal sound would be from it.
Mar 23, 2019 at 11:32 AM
No. The noise is not normal.
I would still have the fluid changed.
Mar 23, 2019 at 11:36 AM
