Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
LS
Drivetrain
Transmission
Reverse
After changing the fluid the transmission will not shift into reverse?
2004 LINCOLN LS
240,000 MILES • 3.0L • V6 • AUTOMATIC
DODGERS
MEMBER
I changed the transmission fluid and now it won't shift into R. Transmission solenoid pack.
Apr 27, 2021 at 4:50 PM
Experienced Mechanic
Good morning,
Engagement of reverse is mechanical, not electronic. I attached a chart of the possible issue for not going into reverse only.
I attached testing for the mainline pressure below to determine if it is an internal issue.
Images (Click to enlarge)
Apr 27, 2021 at 6:34 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
