Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Engine
Symptoms
Stall While Driving
When the transmission is shifted into drive the engine shuts off
2006 TOYOTA AVALON
175,000 MILES
LIBRA718
MEMBER
1 POST
When it starts, I shift the transmission into reverse it works, when I shift it into neutral it works but once I put it in drive it shuts off.
May 5, 2022 at 11:22 AM
Experienced Mechanic
Good morning,
This sounds like the torque converter is locked up causing it to stall in drive and low RPM.
Are there any codes stored?
I would change the fluid and filter to start in case there is debris in the valve body.
May 5, 2022 at 8:09 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
