When the transmission is shifted into drive the engine shuts off
2006 TOYOTA AVALON
175,000 MILES
LIBRA718
When it starts, I shift the transmission into reverse it works, when I shift it into neutral it works but once I put it in drive it shuts off.
May 5, 2022 at 6:22 PM
Good morning,
This sounds like the torque converter is locked up causing it to stall in drive and low RPM.
Are there any codes stored?
I would change the fluid and filter to start in case there is debris in the valve body.
May 6, 2022 at 3:09 AM
