He did not specify which solenoid it may be
136,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
MATTV7821
I bought this car recently and was told by the seller that the transmission was rebuilt at 90,000 miles and the transmission light will start flashing occasionally while drive at highway speeds because of a solenoid in the transmission. The car still performs normally when the light starts flashing, but I would like to fix it to avoid any problems down the road. He did not specify which solenoid it may be so I am wondering if anyone has a good idea as to what is going on and how serious it is and also on how to fix it? I would like to do the work myself, but my knowledge is limited.
Thank you all very much.
Sep 13, 2018 at 2:19 AM
P0741 Code - Check out the diagrams (Below).
Torque converter clutch not engaging when commanded and/or Diagnostic Trouble Codes (DTC) P0741 or P1744 stored in memory.
ACTION
Use a scan tool (NGS/WDS) to monitor PID's to help determine steps to take for service. Refer to the following Diagnostic Procedure for details.
1. For DTC P0741 and P1744, perform Pinpoint test "C" in Section 307-01 of the appropriate Taurus/Sable, Windstar or Continental Workshop Manual and refer to TCC Solenoid Resistance Chart (Figure 1) for correct TCC resistance.
2. Also refer to "Diagnosis by Symptom" Routines 240 and 340 in Section 307-01 of the appropriate Taurus/Sable, Windstar or Continental Workshop Manual.
3. Remove lower pan of the transaxle and check for excessive debris in the pan.
4. Remove the main control cover, main control and pump shaft.
5. Check for pump shaft wear or damaged seals.
6. Inspect the internal wiring harness for damage.
7. Inspect and clean the main control and make sure all valves move freely. Specifically, converter regulator valve, solenoid regulator valve, bypass clutch control valve or pressure fail-safe valve (refer to Figure 2 for Ax4N and Figure 3 for Ax4S).
8. Measure depth of groove in the pump bore ring (Figure 4).
9. If cause for condition has not yet been identified, remove the transaxle and inspect the outer surface of the stator support for damage (Figure 5).
10. Inspect torque converter hub bushing for wear.
11. Inspect turbine shaft seals.
12. To verify the condition has been corrected, the drive cycle must be performed at least five (5) times (for drive cycle procedure refer to the appropriate Workshop Manual Section 307-01). The PCM will not set a torque converter clutch code until it fails to engage five (5) consecutive times.
Sep 17, 2018 at 11:27 PM
MATTV7821
Thank you for your help. A few more questions come to mind. Would it just be easier to replace the torque converter itself? And would that get rid of the code that was detected? Also what would happen if I just ignored the problem?
Sep 18, 2018 at 1:21 AM
Ignoring the issue is never good. It will not stay the same and will cause more damage.
I said it was the most common but it needs to be confirmed before replacing otherwise it is a very expensive guess.
Sep 18, 2018 at 1:31 AM
