Transmission slow to shift from park to drive in cold weather?
75,000 MILES • 0.5L • 6 CYL • 4WD • AUTOMATIC
CRACKERMAN
  • 5 POSTS
During cold months shift from park to drive in the car, sometimes it is not possible until the car warms up. happen infrequently. what are next steps?
Nov 27, 2023 at 8:59 AM
  • 110,246 POSTS
This could be the result of a few things. First, transmission fluid contracts when it is cold. If it is already low, the colder weather may be causing it to drop lower than usable. Have you checked the fluid level and condition?
Next, often times a delayed shift deals with low-line pressure. By any chance, has the check engine light ever been on while the engine is running? If so, have you checked for codes?
Let me know. I just checked to see if there are any technical service bulletins that would be relevant, but there are none.
Nov 27, 2023 at 1:21 PM
CRACKERMAN
  • 5 POSTS
Infrequently since it has gotten cold, shifting from park to R or D will not happen immediately. After 5 minutes warm up, and restart of the car, then it shifts into gear with no problem.
Nov 28, 2023 at 5:17 AM (Merged)
  • 110,246 POSTS
I just responded to a different question related to the delayed shift from park to drive when cold. I saw this and assumed it was for the same vehicle. However, one is a GLK and the other is a CLK. Is this a typo or are we looking at two different vehicles?
CRACKERMAN
  • 5 POSTS
GLK. Thanks
CRACKERMAN
  • 5 POSTS
No engine light on and will need a Mercedes Tech help to check fluid levels and conditions. due to the sealed systems. Thanks
Nov 28, 2023 at 5:25 AM
  • 110,246 POSTS
Okay. I attached a pic below. Which one do you have? There are three different possibilities. I believe there is a way to check the level without going to a dealer.
See pic below.
Nov 28, 2023 at 12:37 PM
CRACKERMAN
  • 5 POSTS
GLK 4 Matic.
Nov 29, 2023 at 3:01 AM
  • 110,246 POSTS
Interestingly, I found a notice that if the fluid hasn't been changed in 70,000 miles, the filter needs to be changed as well. See pic below.
Also, you are correct with this vehicle. It needs to be checked. I have no idea why this has changed other than someone is trying to make more money.
If you haven't serviced the transmission at this point, it needs to be done.
See pic below.
Nov 29, 2023 at 12:56 PM
