Had to pull back my transmission about ten inches to plug a leaky freeze plug, put it back together, it made a bit of noise on starting off, but ran and shifted fine for about three weeks.
I heard something clank on van, could have been road rock or bolt, do not know. Next day problems started when shifting into third, then soon second then first and reverse. Torque converter is making noise, it will engage after thirty second delay but slips out under any load or acceleration. I am going to remove the dust cover and check my bolts on flywheel, and I will change fluid if recommended, the fluid is still red and looks fine, but not sure of grade, but I bought cheap fluid. Have not checked filter, but did not replace when work was done. Any suggestions for a broke DYI repairman?
Nov 8, 2016 at 4:31 AM
