I had the truck on ramps passenger side front and rear the other day to perform routine lubrication. Since then, the transmission is slipping, along with the speedometer reading erratically and the cruise not working.
I checked the wiring harness connector at the transmission and found a little fluid on the two wire connector.
The 'check engine light" is on and flashes sometimes.
Sep 11, 2017 at 4:51 AM
