Transmission slips and hesitates
100,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
PAMMCELHANNON
Feels like it hesitates when accelerating, and slips. Makes a sound like driving on rumble strips with vibration.
Feb 15, 2020 at 8:32 AM
Good evening,
Is the check engine light on? If it is, do you know the code?
It could be a clogged filter in the transmission. How long since you had the fluid and filter changed.
Feb 15, 2020 at 8:50 AM
What is the fluid condition like? Should be pink and not smell burnt. If the fluid is low then it will cause hesitations during acceleration. However, the vibration is caused by the clutches slipping so we need to make sure the fluid is not burnt.
Let's start with checking the fluid quality and go from there. Next thing is to check for codes. I doubt you will have any but we need to check.
Feb 15, 2020 at 9:00 AM
