transmission slips?
130,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
RECKLESS300
Generic code reader says governor solenoid electrical, but I've replaced them and the wiring inside the transmission still have the issue any help would be awesome. The vehicle listed above is an SLT model.
May 18, 2025 at 8:04 AM
  • 55,616 POSTS
Do you have the code number? I need it to help you. FYI, if the transmission is having a mechanical failure it will have shift and governor codes. I would check the level and condition of the transmission fluid. Also, please go over this guide as well.
Please go over this guide and get back to us.
May 19, 2025 at 7:14 AM
