transmission slipping at low speeds and start from stop
168,000 MILES • 1.9L • FWD • AUTOMATIC
SAM629
the can filter was changed cause i thought it was due to worn fluid and clogged filter it was jerking till i got speed p to 40-45 after that it dont happen till i slowed down . i went to parts house they say it has a secong filter inside trans with, but couldnt tell me where it is. i check with local trans shops and they dont work on them i am in waycross ga. how do i change inside filter or do you think jerkng is another problem . dealer wants too muck to check it out so thats out
pleae help me with this issue asap my wife drives it t work.
Aug 1, 2015 at 11:18 AM
SATURNTECH9
  • 30,869 POSTS
The inside filter is inside the transmission you have to split the case of the transmission they only get changed when a internal repair is made thats not your problem.Do you have a delay/bang when shifting it into reverse?Also any trouble codes in tbe computer?
Aug 2, 2015 at 6:55 AM
SAM629
havent checked codes yet but yes to the delay in reverse and forward
Aug 2, 2015 at 12:12 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like you have a low line pressure issue in the transmission from ethier a loose input shaft nut or a worn pressure regulator bore inside the valve body.With doing a pressure test on the transmission with a transmission pressure tester gauge its hard to say.
Aug 2, 2015 at 3:17 PM
