Transmission slipping
177,000 MILES • 3.6L • 6 CYL
LORI VEGA
  • 20 POSTS
When driving the transmission is slipping through all 4 gears and when it's in third and fourth gear it is like they're gone.
Both shift solenoids have been replaced.
Aug 19, 2019 at 6:45 PM
Good morning.
How long since you changed the fluid and filter? It may be a clogged filter.
Beyond that, it is an internal failure. If the fluid change does not resolve it, the transmission will have to be replaced.
Aug 19, 2019 at 8:37 PM
LORI VEGA
  • 20 POSTS
We did the code reader and it showed the transmission control module sensor and a o2 sensor. Thank you
Aug 20, 2019 at 6:58 AM
What were the code numbers?
Aug 20, 2019 at 8:11 AM
LORI VEGA
  • 20 POSTS
Thank you for your response. I know 1 code was for the o2 sensor and the other code was the transmission controls module. I will have to find the paper the codes were right on.
Aug 22, 2019 at 3:58 AM
Let me know when you can and I can help you more.
Aug 22, 2019 at 5:01 AM
LORI VEGA
  • 20 POSTS
Thanks Roy.
Unfortunately I cant find the paper with the codes on it.
All I know was 1 code was the o2 sensor
And the other code was the Transmission Control Module sensor.
Aug 22, 2019 at 10:41 AM
There are many codes for the module. See if you can have someone check it for you.
A parts store will do this for free.
Aug 22, 2019 at 10:49 AM
