Transmission slipping
110,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
THEJAGUAR97XK8
This just happened today, transmission is slipping bad when put in "drive", no warning light or "fail safe" indicator. When put in "park", vehicle lurches forward about three inches. Previously I had noticed that when climbing a steep hill under speed (approximately 50 mph) that there seemed to be a lack of power to gain more speed.
Any ideas such as the torque converter?
Nov 12, 2018 at 3:06 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Has routine transmission services been performed? If you can check the the transmission fluid color/odor (smells burnt) and get back to us that would be able to help diagnose. Also, is the check engine light on? I have attached a few tutorials for you to help. Hope this helps and thanks for using 2CarPros.
Danny-
Nov 12, 2018 at 4:30 PM
