Transmission slipping
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
KILLAKODY
I have the ES model. I just had a new clutch put in it. Got to drive it for a month, and while going up a hill, the rpm’s was rising and the car was not going anywhere. Now anytime I try to do a hard take off, the car will not move, only rev. I can have it in fifth gear, and floor it, and the rpm's will rise, but not the speed.
Aug 5, 2018 at 3:14 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Yes, your new clutch is slipping. Possibly you got a defective disk. All that revving and slipping is just burning that disk up. Did it come with any type of warranty? Was the flywheel resurfaced when clutch installed? I have attached a link for you to look at. Hope this helps and thanks for using 2Carpros.
Danny-
https://www.2carpros.com/articles/clutch-symptoms
Aug 6, 2018 at 11:15 AM
