Truck goes in all gears first, second, third and overdrive . The problem happens when it goes to shift gears it starts slipping and revving up.
Nov 23, 2017 at 9:27 AM
✓Experienced Mechanic
Make sure the transmission fluid is full and clean. If the check engine light is on, have the computer scanned to determine if there is a trouble code related to the transmission. If there is, let me know what it is. If the fluid is full and clean, no codes, and this is the original transmission with 170,000 miles on it, it may need rebuilt and is slipping due to wear.
