Transmission solenoid replacement
191,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
THEFORGE1981
Got the dreaded solenoid code and lost overdrive. how do I change them? Do I have to drop the transmission or can it be done mounted through the oil pan? Also, where can I purchase the solenoids?
Sep 17, 2016 at 3:25 PM
AL514
  • 5,700 POSTS
What transmission code did you get? It may not be the solenoid. May be the TCM, (Transmission Control Module) I have had many wiring problems on the Eclipse also. All kinds.
Sep 17, 2016 at 10:25 PM
AL514
  • 5,700 POSTS
Also, the Solenoids are located inside the transmission, can be accessed by dropping the pan. But check for circuit or module problem first, ie going by the code number.
Sep 17, 2016 at 10:27 PM
THEFORGE1981
P1750 already replaced TCU and fuse got 1-3 fine no OD and oif you push in the button other will struggle trying to engage then shift erratic.
Sep 17, 2016 at 11:37 PM
AL514
  • 5,700 POSTS
P1750 transmission solenoid assembly code. I guess from a little research, they are deep inside the transmission. You have to remove the pan, filter, and valve body to get to it. There is a ton of resistance tests you can do. To check each solenoid, but this does not look like an easy job by any means. I would erase the code and go for another test ride, I know you do not have OD, but see what codes come back. There also could be a problem in the harness between the TCM and transmission. I have found tons of corroded connections on the Eclipse that led me all over the place at times. Check circuits before tearing the transmission apart. I do not think the solenoids are very expensive, just hard to get to. Hope this helps some.
Sep 18, 2016 at 3:18 AM
  • 55,770 POSTS
Another great answer! nice work AL514
Best, Ken
Sep 19, 2016 at 2:47 PM
