Transmission delay in shifting problem
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAYEE4LIFE
  • 11 POSTS
It seems like that there is a delay in shifting from 3-4 and/or 4-5. When I keep on pressing the accelerator pedal then it takes a little long, but if I go a little easy (which is abnormal) then the shifting is fine. Other wise the shifting of the rest of the gears is normal.
Apr 3, 2020 at 12:31 AM
  • 110,248 POSTS
The harder you accelerate, the longer it will take for the shifts. The RPM's will increase higher before shifting. Is that what is happening? By any chance, is the check engine light staying on when the engine is running?
Apr 3, 2020 at 4:13 AM
DAYEE4LIFE
  • 11 POSTS
I didn't notice the rpm. There is no check engine light.
Apr 3, 2020 at 10:47 AM
  • 110,248 POSTS
Check to see if the RPM's are simply increasing because you are accelerating faster. I have a feeling that is what is happening. I am basing that on the idea that you mentioned it shifts normally if you are easy on the throttle.
Apr 3, 2020 at 11:14 AM
DAYEE4LIFE
  • 11 POSTS
Okay. Let me check and get back to you.
Thank you Joe.
Apr 6, 2020 at 2:26 AM
  • 110,248 POSTS
You are very welcome. Let me know what you find or if you have other questions.
Take care and I hope you are well.
Apr 6, 2020 at 2:34 AM
DAYEE4LIFE
  • 11 POSTS
Unfortunately this truck doesn't have a rpm gauge!
Apr 7, 2020 at 7:57 AM
  • 110,248 POSTS
No problem. Can you hear the engine increasing in speed as the vehicle does the same?
Apr 7, 2020 at 11:22 AM
DAYEE4LIFE
  • 11 POSTS
Good morning Joe. I did, but no it doesn't increase in speed!
Apr 7, 2020 at 11:48 PM
  • 110,248 POSTS
Okay, if the engine RPM's are increasing but the vehicle isn't, it almost sounds like the transmission is slipping.
I need you to check the transmission fluid level to confirm it is clean and full. Here are the directions for doing it.
____________________________________
Engine RPM must be at idle before starting the level check. Keep the transmission fully warmed (valve body ATF temperature: 158-176°F/70-80°C) during the procedure.
1. Park the vehicle on level ground, set the parking brake, block the wheels and start the engine.
2. With the engine idling and regular brakes applied, shift the gear slowly in every range from P to 1 range, and return to the P range.
see pic 1
3. With the engine idling, remove the level gauge and clean off any fluid or foreign material. Insert the level gauge, remove it again, and confirm that the oil level is within the 'HOT' range.
Apr 8, 2020 at 11:13 AM
DAYEE4LIFE
  • 11 POSTS
Okay Joe. Will do.
Apr 9, 2020 at 3:07 AM
  • 110,248 POSTS
Sounds good. Let me know what you find.
Apr 9, 2020 at 9:17 AM
DAYEE4LIFE
  • 11 POSTS
I checked. It's not in the 'H" range. What oil shall I use?
Apr 10, 2020 at 12:25 PM
  • 110,248 POSTS
What I am seeing for a 2001 is Dexron III. See attached picture.
Is the fluid clean? (red in color)
Apr 10, 2020 at 2:01 PM
DAYEE4LIFE
  • 11 POSTS
Hi. Yes the fluid is clean. (red in color.)
Thank you for your time Joe.
Apr 10, 2020 at 2:58 PM
  • 110,248 POSTS
You are very welcome. If you have other questions or need anything, let me know.
Take care, stay healthy, and have a Happy Easter!
Apr 10, 2020 at 3:16 PM
DAYEE4LIFE
  • 11 POSTS
Hi. I added more ATF and the level is correct, but the problem still exists!
Apr 15, 2020 at 1:45 PM
  • 110,248 POSTS
Is it possible for you to drive the vehicle and record what it is doing so I can hear and see what you are experiencing?
Apr 16, 2020 at 11:58 AM
DAYEE4LIFE
  • 11 POSTS
Hi. Sure I can Joe.
Apr 17, 2020 at 5:00 AM
