Transmission shifting issue
THEMADCANADIAN
  • 1999 DODGE DAKOTA
  • 3.9L
  • 4 CYL
  • RWD
  • 184,000 MILES
I bought a clean magnum, sometimes it starts off in second gear and sometimes it stays in second until it almost to red lines then I let off the gas and go normally then it will shift into third. Ninety five percent of the time he wont shift into fourth gear. Sometimes, rarely at 80-90 km/h it feels like a mini overdrive that lower the rpm's from 2300 to 2000 or 2100, but it is not in fourth gear.
Thursday, November 10th, 2016 AT 6:40 AM
KOOLCADDY6
  • 60 POSTS
If you can get the codes on the transmission read with a scan tool. It sounds like the transmission is in limp mode. Could be just a sensor issue
Thursday, November 10th, 2016 AT 8:37 AM
