Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
300
Drivetrain
Transmission
Symptoms
Not Shifting
transmission shift problem?
2007 CHRYSLER 300
260,000 MILES • 2WD • AUTOMATIC
TRAVIS COBLE
MEMBER
1 POST
it will crank and run and will go into first gear but won't shift into any other gear.
Feb 17, 2023 at 6:23 PM
Experienced Mechanic
This sounds like the TCM went out or the second gear shift solenoid is not working. We should run the codes to see what comes up.
Here is a guide to help us:
Is the speedometer working? The TCM is under the dash on the driver's side. Please check out the images below to see the location.
Images (Click to enlarge)
Feb 18, 2023 at 10:45 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
