Transmission shifts hard once it gets warm
2007 PONTIAC G6
142,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MKFARREN
  • 36 POSTS
My daughter's car shifts hard after you drive it about fifteen to twenty miles. Before that, it is smooth. There is about 142,000 miles on it and sometimes it will put out an 1811 code for too long to shift, but only once it is warm. It also drops really hard into drive and reverse after it is driven, but not when it is cold or warming up. Has about 28,000 on the fluid and filter. Shift solenoid? Dirty fluid?
Thanks in advance.
Sep 14, 2018 at 11:40 PM
Good afternoon.
Yes, I would start by changing the trans oil/filter.
It sounds like a valve body issue. Possibly a servo spring may have broken.
Transmission Shifts Hard
Diagnostic Aids
An intermittent hard shift may be caused by an intermittent clutch condition.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
3. A static shift test is performed by shifting into all of the gear positions with the engine not operating. While performing the test one should note how the shift lever movement is felt. Also while shifting from one gear to the other feel for binding in the shift rails. You should be able to feel the detent plungers operating when coming out of a gear and going into a gear.
6. A dynamic shift test is performed by shifting into the gear positions with the engine operating. Test for the correct mesh of the synchronizers and for the clutch releasing correctly. When shifting into and out of a gear, feel for the shift detent plungers and for the synchronizers sleeve for moving freely.
8. The transaxle uses a Castrol BOT 0063 (P/N 21018899) transaxle fluid that allows proper synchronizer operation. The incorrect fluid may cause hard shifting by varnish build-up, or not enough lubrication for proper synchronizer operation.
Sep 15, 2018 at 2:55 AM
MKFARREN
  • 36 POSTS
Thanks, I will try these this afternoon and report back.
Sep 15, 2018 at 3:43 AM
Sounds like a plan.
Sep 15, 2018 at 3:51 AM
MKFARREN
  • 36 POSTS
So far so good, fluid and filter change, magnet had an average amount of goo on it. Cleaned everything up and so far it has done it once since. I had the scan tool plugged up and was driving it when it happened, cleared the code again and so far it has been gone since that stoplight. Here is to hoping, lol. Thanks!
Sep 16, 2018 at 12:37 PM
Good deal.
Keep me updated.
Sep 16, 2018 at 1:03 PM
MKFARREN
  • 36 POSTS
So far so good, I have not had a chance to report back. I have put about 1,200 miles on it and it has done it about five total times max. Goes away after a computer reset or leaving the ignition off about two minutes. Totally drivable now.
Nov 6, 2018 at 7:26 AM
Good news.
I would change the oil/filter again to get more of the debris out of it.
Nov 6, 2018 at 7:29 AM
MKFARREN
  • 36 POSTS
I will try that and report back in the next couple of days.
Nov 6, 2018 at 7:31 AM
Sounds like a plan.
Nov 6, 2018 at 7:32 AM
