Transmission does not shift into low gear
170,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JEFF MAZZEI
Transmission will not go into low gear.
Jun 20, 2018 at 2:45 AM
  • 110,248 POSTS
This problem can be the result of a couple different issues. First, make sure the transmission fluid is both clean and full. A partially plugged transmission filter can cause low pressure and shifting issues.
If you find the fluid is fine, then I suggest scanning the computer for trouble codes. If there is a problem with a shift solenoid, transmission control module it should have identified the issue and stored a code. Here is a video which shows how to use a scanner:
https://youtu.be/YV3TRZwer8k
If you find trouble codes stored in the system, write them down and let me know what they are so I can further help.
Jun 21, 2018 at 12:26 PM
JEFF MAZZEI
Is it possible that a fuse could be blown?
Jun 23, 2018 at 9:45 AM
  • 110,248 POSTS
Hi again:
No, the shift solenoids are not fused.
Jun 23, 2018 at 12:45 PM
