Transmission service required ads light and gas gauge drop to zero?
180,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MICHEL12345
After replacing the front passenger side wheel bearing by s mechanic I drove off slowly and transmission service required light on cluster,call the mechanic and tell him he told me it will go off by itself because he added oil to the transmission I hang up and speeding up on the highway around 80 km/h transmission service required goes on ads light and gas gauge drop to zero the car give knock and drag down like a manual I put the car to neutral on side of the road didn't put it on park left it in neutral but when put in drive it kicked I drove slowly then put the car in park turn off the engine wait about 5 minutes restart and drove slowly to the mechanic avoiding to go over 80km/h + the mechanic change the speed sensor -abs ,stop switch did a alignment and it still does the same he unplugged the abs sensor and told me to try it,I didn't try it because it dangerous and the gas gauge doesn't work
Jan 9, 2026 at 5:53 AM
MICHEL12345
After replacing front passenger side wheel bearing, diving slowly dash light appear "service trans required" light on I call the mechanic,tell me it go off by itself because he added oil in the transmission.. after speeding up on the highway around 80 km/h abs light goes on the car and the gas gauge drop to zero the car is dragging slowly down like a manual I put the car in neutral stops on side of the road and when I put in gear it gave a hard knock I put in park and stop the car and waited 5 minutes then star and when back to mechanic to check I drove slowly on small road to avoid going over the 80km/h + .they change the stop switch, speed sensor,did a alignment and it still does the same,when back to mechanic he unplugged abs and told me to try it I didn't not try by fear of getting hurt. Thanks
Jan 9, 2026 at 8:37 AM (Merged)
  • 55,709 POSTS
Yep, it sounds like the car is going into limp mode, so we need to run the codes to see what system is having the problem. Before heading off in the wrong direction and through parts at it lets pinpoint the problem by following this video.
CAN SCAN - https://youtu.be/u-4syLc-ifQ
Please go over this guide and get back to us.
Jan 11, 2026 at 1:53 AM
