Transmission service
100,764 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PCHEFSONYA
  • 31 POSTS
I cannot find any information on how to check or refill transmission fluid after replacing the transmission for customer. Any help would be appreciated.
Nov 16, 2017 at 10:42 AM
STEVE W.
  • 15,418 POSTS
That should be a 6F35 transmission, It has a level plug on the left side near the CV axle check with fluid warm and it should be level with the hole. The fill port is on the top front of the trans, should have a plastic cap that looks like a breather cap.
Be sure to use MERCON-LV fluid if you want the transmission to last.
Nov 16, 2017 at 1:56 PM
