How many transmission sensors on this vehicle?
95,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
DAVID CHANDLER FARR
  • 41 POSTS
How many sensors are on the transmission I see 4 parts on it with wires four different sensors or plugs.
May 8, 2025 at 1:20 AM
STEVE W.
  • 15,422 POSTS
What error codes do you have that say there is a sensor problem? Those rarely fail without setting codes.
May 8, 2025 at 3:59 AM
FARR2007
  • 244 POSTS
That’s not what I asked, I asked how many sensors are on the transmission and what are they for because I see 4 of them.
May 8, 2025 at 4:08 AM
STEVE W.
  • 15,422 POSTS
There are 2 sensors, input and output speeds, the other connections are to the solenoid pack and the shift range switch. I have read your other posts as well. Without a scan tool to look at the data you could replace the entire transaxle and still have the same issue.
May 8, 2025 at 10:14 AM
FARR2007
  • 244 POSTS
I will take pic of the sensors, and you can tell me what they are, but I see 4 connectors and then the solenoid pack.
May 8, 2025 at 10:22 AM
STEVE W.
  • 15,422 POSTS
There are 2 sensors that can be accessed on the outside of the transmission. Those are the input and output sensors. The others are harness extensions for internal parts like the range switch, solenoid pack and temperature sensor.
May 10, 2025 at 10:25 AM
