While driving transmission seems like it went into neutral
160,000 MILES • V8 • 4WD • AUTOMATIC
DANNACY01
While driving transmission seems to have gone into neutral, no warning. Cannot get it to go into any gear.
May 20, 2018 at 3:03 AM
Good afternoon.
Check the fluid level.
Does it go into reverse?
Change transfer case selections and see if it goes into gear.
How does the fluid look? Is it red or brown? When the last time you have the oil/filter changed on the transmission?
May 20, 2018 at 5:12 AM
