Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
LS
Drivetrain
Transmission
Seal
Transmission seals
2004 LINCOLN LS
100,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
BRIAN CHILDRESS
MEMBER
I'm putting a 2004 transmission in a 2003 Lincoln ls v8 and I'm changing the front and rear seals before I put it in.
Sep 14, 2021 at 3:17 AM
Experienced Mechanic
Good evening,
I attached the procedure for you for the replacement of the rear seal. Make sure you lube up the seal before installation.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
The front has 2 seals. One for the pump and one for the stator shaft. I attached the procedure for both for you below.
Let us know if you have any other questions.
Images (Click to enlarge)
Sep 14, 2021 at 10:31 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
