Transmission Replacement
144,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MINCHTHOMAS4
  • 5 POSTS
Need step by step instructions on replacing the transmission in my front wheel drive 2005 Ford Freestyle
Apr 25, 2022 at 9:49 AM
  • 110,251 POSTS
This is a big job that will require special tooling. You will need an engine support to hold the engine in place when removing the transmission.
I included the removal and installation directions below. They are quite extensive but don't be overwhelmed.
Take a look through these and let me know if you have questions.
Apr 25, 2022 at 1:53 PM
MINCHTHOMAS4
  • 5 POSTS
Thanks a Million Joe F.
Apr 25, 2022 at 2:02 PM
SQM
  • 6,383 POSTS
See attached for the complete replacement procedure for the transmission, including all the torque specifications and needed special tools.
Let me know of any questions.
https://www.2carpros.com/articles/how-to-remove-an-automatic-transmission-rwd
Apr 25, 2022 at 2:04 PM
MINCHTHOMAS4
  • 5 POSTS
Thanks Sean M.
Apr 25, 2022 at 2:06 PM
SQM
  • 6,383 POSTS
You are welcome.
Apr 26, 2022 at 5:05 PM
MINCHTHOMAS4
  • 5 POSTS
Does the 2007 Ford Freestyle transmission work for the 2005 Ford Freestyle??
Apr 28, 2022 at 9:47 AM
  • 110,251 POSTS
I looked up part numbers for both model years and included them below. They are the same part number, so it should work.
However, this is a CVT transmission. If the one you plan to use has a lot of miles, consider rebuilding it prior to installation. This transmission design hasn't been the longest lasting.
2005 -- 7F9Z7000A
2007 -- 7F9Z7000A
Interestingly, the part is identified as a CVT in the manual, which to the best of my knowledge is. The removal and replacement that both Sean and I provided show it as a 6-speed automatic. I'm waiting for confirmation.
Apr 28, 2022 at 12:12 PM
MINCHTHOMAS4
  • 5 POSTS
Thanks again Joe F.
Apr 28, 2022 at 12:15 PM
  • 110,251 POSTS
You are very welcome. Let us know if we can help.
Apr 29, 2022 at 11:38 AM
