Transmission replacement I'm about 3/4 of an inch away from getting it in
200,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
RYAN SULLIVAN
I dropped the transmission to replace the clutch slave cylinder and throw-out bearing. now that I'm putting the transmission back in place I'm about 3/4 of an inch away from getting it in it's lined with the spline and the clutch pad.
Jul 31, 2019 at 3:57 AM
Hi Ryan,
Are you using the clutch alignment tool? If not, the disc is getting hung up on the input shaft. I know you said it is inline but if you are not using that tool then it may just look like it is lined up but if they are just a fraction off, then it will get hung up right where you are getting to.
https://www.2carpros.com/articles/how-to-replace-a-clutch
May 4, 2021 at 3:54 AM
