2003 Ford Ranger XLT 2.3 automatic 2x4. Keep getting po705. Replaced TRS worked great for about 2 months and the code is back. Replaced the TRS again cleared codes and the po705 comes back soon as I start the truck. If I push O/D OFF button I can manually shift it up thru the gears and when up to speed turn on O/D and it does at should. Truck starts in park, goes into reverse but barely wants to pull. Looking for a TRS plug in wire diagram and a PCM pigtail diagram so I can test both for signal, broken wire,or corroded wire, bad TCM. If I end up having to replace ECM will my PATS system still work or is it a trip to Dealership to get it all programmed? New to this forum and help would be appreciated.
Jan 2, 2026 at 11:24 PM
