Where is the transmission range sensor located?
159,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
KRISTINAP
I can’t get my car started because it’s not reading that it’s in park. I can’t seem to locate the transmission range sensor. I used to be able to wiggle wires around and it would read it’s in park and I could start it and be on my way. This time that’s not working.
Sep 12, 2025 at 4:41 AM
STEVE W.
  • 15,410 POSTS
Where were the wires you wiggled? Unless you were wiggling the harness inside the transmission it likely isn't the position sensor. Instead it is probably a broken wire or connector in the area you were moving the wires. I would look there for a damaged or broken wire.
Sep 12, 2025 at 4:53 AM
