Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Drivetrain
Transmission
Gear Position Sensor
Location
Transmission range sensor location
2002 FORD WINDSTAR
300,000 MILES • 6 CYL • AUTOMATIC
JACSBRATT
MEMBER
What is it? tried looking it up at parts store it comes up speed sensor. is that the same thing? and where is it located?
Jun 14, 2019 at 3:36 AM
Experienced Mechanic
Hi Jacsbratt,
The range sensor is not the same as the speed sensor. The TRS is a switch that tells the PCM which gear the transmission is in (P,R,N,D).
It is located on top of the transmission where the gear selector connects to the transmission.
I included all the needed documents. Let me know if you need anything else. Thanks.
Images (Click to enlarge)
Jun 14, 2019 at 5:12 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
