next thing to do is get a line pressure test done, this will see if pump and governor are working properly, not sure if your transmission is wired for live data read, but if it is this will also help the mechanic to see if all shift solenoids are working correctly, also the Converter lock up clutch may be permanently engaged and the car is trying to drive off in top gear.
Oct 12, 2017 at 9:17 PM
