Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Vue
Drivetrain
Transmission
Gear Position Sensor
Replace/Remove
Transmission range sensor
2003 SATURN VUE
12,999,999 MILES • 2.2L • 4 CYL • AWD • AUTOMATIC
MARGI TYLER
MEMBER
1 POST
How do I change the transmission range sensor?
Sep 24, 2016 at 5:20 AM
Experienced Mechanic
You will need to start by setting your emergency brake and disconnecting the battery. Here is a guide that will help you get started.
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
Check out the diagrams (Below)
Cheers, Ken
Images (Click to enlarge)
Feb 19, 2018 at 8:16 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
