Transmission quit pulling
DAKOTA DILLON
  • 1998 DODGE DURANGO
  • 5.2L
  • V8
  • 4WD
  • 299,000 MILES
I was driving and stop at stopped sign took back off and truck would not pull anymore. It will shift into gears but will not move. Checked fluid levels all correct.
Thursday, November 22nd, 2018 AT 1:23 AM
  • 52,797 POSTS
Good morning,
If the fluid level is good, then I would drop the pan and check and see if the filter is clogged or there is debris in the pan.
If the filter is not clogged, then you have an internal failure.
I would start by changing the fluid and the filter before assuming there is an internal failure.
Thursday, November 22nd, 2018 AT 4:14 AM
