Transmission stopped working while driving, no drive and no reverse
100,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
HELP10000
I was driving and my transmission mission quit, no reverse or drive. I pull pan fluid looked good no metal shavings etc. I replace shift solenoids a and b. Replaced fluid and filter. Cranked it up still nothing. What is my problem?
Mar 23, 2019 at 7:22 AM
Good afternoon,
Sounds like either the front pump or the torque converter has failed. It is an internal failure and the transmission will have to be removed and inspected for the failure.
Mar 23, 2019 at 7:32 AM
HELP10000
Turns out both has failed. replacing and doing a fresh up on it.
Apr 13, 2019 at 4:38 AM
Good deal.
Apr 13, 2019 at 6:14 AM
