Transmission problem
121,211 MILES • 3.5L • V6 • 4WD • AUTOMATIC
RFTAYO
My gear accelerate well but after sometime it will start reducing from upper gear to lower gear. that is from gear 5 to gear 1 until it stop moving. And when it is parked for like 30 minute it start working again.
Oct 20, 2019 at 7:45 PM
Good morning,
How long since you change the fluid and filter in the transmission? A clogged filter could cause this issue.
Is the check engine light on with stored codes? If it is, you can get them read at a parts store for free.
Oct 20, 2019 at 11:51 PM
