Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Malibu
Drivetrain
Transmission
Replace/Remove
transmission programming
2009 CHEVROLET MALIBU
108,262 MILES • 2.4L
TRANSMISSIONS PLUS
MEMBER
1 POST
i wanted to know if you install a used transmission in the vehicle do you always have to have it programmed or only if it does not work properly?
Nov 9, 2016 at 3:36 AM
SATURNTECH9
Experienced Mechanic
No you do not have to have it programmed. It would be best to have the transmission adaptives reset though after the transmission is installed.
Nov 9, 2016 at 4:48 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
