Car will not move once in gear
100,000 MILES • 3.8L • 6 CYL • 2WD • MANUAL
JOHN CHRISTOPHER DELGADO
Just bought the car listed above (V6) and a week later it won't move once in gear. Goes into gear smoothly just won't move. Trying buy parts but not sure what to buy. Any input would be appreciated.
May 6, 2019 at 10:36 AM
Good morning,
Does it go into reverse?
I would start by changing the fluid and filter in the transmission to be sure the filter is not clogged.
Make sure there are no leaks as well. Low fluid level would cause this as well.
May 6, 2019 at 9:46 PM
Yes goes into reverse but still doesn't go anywhere.
May 6, 2019 at 10:22 PM
Okay, I would start by servicing the transmission.
May 6, 2019 at 10:41 PM
What would be your opinion about the flywheel or pressure plate being the cause?
May 6, 2019 at 11:30 PM
Sorry, did not know t was a stick shift.
Yes, the clutch sounds like the issue.
May 7, 2019 at 1:01 AM
