Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
CRV
Drivetrain
Transmission
Transmission problems
2002 HONDA CRV
166,000 MILES • 1.2L • 4 CYL • 4WD • AUTOMATIC
HOSAM HAG
MEMBER
At scanner do a problem with solenoid c.
Dec 25, 2019 at 12:32 AM
Experienced Mechanic
If you found a code for the solenoid then most likely it has failed and needs replacement. Let me know what the code is and we can get you the detail.
I attached the detail about the solenoids. Let me know if you have questions. Thanks
Images (Click to enlarge)
Dec 25, 2019 at 10:10 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
